What stroker to go with?
Just got the ultimate X-Mas gift a ohio forcedinduction turbo kit from my wife and was wondering what stroker to purchase for a 6.0 iron block with some 317 heads. I never really hear anyone purchasing a stoker kit from eagle or callies. Is it cheaper to buy the parts separate? I want a 408 that is able to put out 1000 to the wheels. thanks
got a Callies Kit, cant go wrong, they are very reliable. It is cheaper most of the time to get the kit than purchasing them separately. cant go wrong with one of these kits from a reputable sponsor on this site http://www.ls1speed.com/cont.cfm?cid=C0000184
I would try to use someone that is local to you..or that you can drive to. HKE is in Houston and does good work. We've used him for several motors and they have all been fine. No oil pressure problems!
Here is also another good kit from Wheel to Wheel, another very good known sponsor on this site. This kit claims to be able to hold 1500hp
http://www.w2wpowertrain.com/pc-69-3...plication.aspx
We use Callies Compstar, Callies Dragonslayer and Callies Racemaster crankshafts on our builds, have not had problems with any of them. We use Callies Compstar connectings rods on most of our builds and never have had a problem with them either. For pistons we usually go with Diamond, for rings we use Total Seal. Bob
we also sell our well proven boost 6.0 motors for $3399
Includes Eagle H beam rods with ARP rod bolts
Diamond -15cc pistons/ plasma moly ring set/Clevite bearings.
no core charge
Boost prepped 403 Iron shortblock $4350
Compstar rotating assembly with Diamond pistons -15cc
L92 416ci shortblock $4850
same parts as above, L92 aluminum block
no core charge
