exhaust exiting in front of rear wheels
Re: exhaust exiting in front of rear wheels
i was looking to do that with mine but you will have to get oval tubing and be really carefull, i was wanting to put side graound effects on and make it come out the ground effect peaice but after i looked how much room wasnt there, i changes my mind and simply put a turndown on!
On my 00 I've had true duals that exit on the side for a while.
My set up consists of:
2.5 inch mandrel bent pipes
2.5 inch H-pipe
Chamberred mufflers with 2.5 inch inlet/outlet, 2.5 inch inner baffle, and 3inch out diamater.
Chrome Z28 style tips that exit on the sides right below the end of the stock T/A ground effect.
Many people have told me that this is the best sounding F-body they've heard. At idel is sounds lopey (Ive been asked what cam I have). Cruising around town it is very deep and sounds great at all rpms. It has no rasp. If it does have any I cant tell because I was so used to the rasp from the Loud mouth with long tubes.
2.5 inch H-pipe
come on guys more input please, what about mufflers? sprial flow or magnaflows? x or h pipe? pics of routing something....
