Am i going to have issues with 315's on my tt2's?
Old 12-26-2007, 07:28 PM
Scammer Alert!
Ricks99ls1's Avatar
Default Am i going to have issues with 315's on my tt2's?
I have a 99 firebird, bumpstops removed, i am getting my torue thrust 2's soon and i have the 315 in the rear, i was looking to do the heater hose mod, where the hose gets wrapped over the top coil on the spring, am i going to have any problems running that large of a tire? Will i need a panhard bar? any help would be appreciaed, i didnt purchase these yet and would like to know your guy advise before i do. Thank You Ricky
Old 12-26-2007, 07:43 PM
Raise's Avatar
no problem at all because of the offset of the wheel. when u get into the 50+ offset in the rear, thats when u start rubbing
Old 12-26-2007, 08:25 PM
Scammer Alert!
Ricks99ls1's Avatar
excellent, so the torque thrust offset doesnt come in the 50+ offset? I appreciate the help Raise!
Old 12-27-2007, 08:16 AM
Raise's Avatar
46mm i believe. i think the 50mm is strictly the zr1 wheels. i had the tt2s with 315s and didnt need spacers or have to bang in the inner wheel well. u will be fine. the lower the offset, the more the wheel will stick out, and the tt2 sticks out a lil further than the zr1s so it sits perfectly flush with the fenders. its a great look from the rear
Old 12-27-2007, 11:02 AM
neeshSS's Avatar
i would still suggest an adj. panhard bar..
Old 12-27-2007, 12:09 PM
DopdBrd's Avatar
Had 315/35ZR17 BFG KD's on the rear of mine with TTII's and Eibach Sportlines and they didn't hit at all!
Old 12-27-2007, 12:21 PM
TomZwheels's Avatar
You should not have any problems at all with either the TT2's or the TTM's.
Old 12-27-2007, 04:34 PM
Scammer Alert!
Ricks99ls1's Avatar
excellent fellas, appreciate the help
Old 12-27-2007, 09:02 PM
Raise's Avatar
u got it man
Old 12-27-2007, 11:38 PM
Clayman's Avatar
I had a little bit of rubbing on mine, but it was really only enough to polish up the metal a bit, and it didnt damage the rim or tire at all.
