Will I need a tune?
Old 12-26-2007, 07:58 PM
shdybrady1988's Avatar
Default Will I need a tune?
I am installing a full exhaust, a lid, p&p throttle body, 85 mm mafs, making my own smooth bellows, and also doing the throttle body bypass. First off will the ported throttle body and 85 mm mafs be compatible with them selves and a ls6 intake? And will i need a tune?
Old 12-26-2007, 08:14 PM
silverLSWON's Avatar
if it's the slp maf then no but you should in order to get the most out of it. a stock GM maf will require the truck or z06 maf table in your tune. a tune will def help
Old 12-26-2007, 08:21 PM
how much are tunes? I did want to spend hundreds on a tune bc i wanted to get all the other parts installed and then tune the car when i got the heads and cam.
Old 12-26-2007, 08:40 PM
Titanws6's Avatar
Have you already done the exhaust?
Old 12-26-2007, 08:43 PM
i am about to. My car gets out of the repair shop tomorrow and ill do it tomorrow. Why do you ask?
Old 12-26-2007, 08:47 PM
Titanws6's Avatar
Defintly go with a tune then, I did similar mods at the same time, a dyno tune will run about $350/375, well worth it . It really ties all the mods together at once.
Old 12-26-2007, 08:48 PM
could i install everything but the mafs and be alright without a tune for a bit. Ill have to save up alil bit for the tune
Old 12-26-2007, 08:54 PM
Titanws6's Avatar
Yeah, later down thr road as you add more stuff, they should only charge like $50 to adjust the tune.
Old 12-26-2007, 08:55 PM
ok well should i go ahead and buy the mafs? also will you look at the other post i did abotu the cai vs ram air and imput in there?
Old 12-26-2007, 09:02 PM
Titanws6's Avatar
Yeah, saw that and am not sure w/ a SS Hood. I have a Ram Air an SLP Lid.
I guess if you have the $$$$ for all the goods, go ahead and do it at once.
