Ms Eliz
12-27-2007, 11:34 AM
:corn:I got this for X-Mas for myself!!!
I want to keep an eye on my N2O, anybody else ever run this set up? Doesn't seen to be to popular.....but, got a great deal on that auction site.
http://i155.photobucket.com/albums/s283/mseliz007/O2_ALERT_unit.jpg
The O2alertis the first data recording system specifically designed to record Air/Fuel Ratios with a warning output! Not only does it record up to 2 Wideband Oxygen sensors but it also records engine RPM , battery voltage, and has a programmable Warning output to protect against "lean-out".
Unit is housed in a durable aluminum extrusion with backlit display and is only 4"x3.25"x1.25".
Standard System comes with 1 wideband sensor, engine RPM (does NOT require additional rpm module as with other systems), Battery Voltage, Warning output, and software.
System has options for 1 additonal built in wideband oxygen sensor, plus (EGT) thermocouple, plus 2 analog channels (RPM, pressure, flow, position, external wideband (see our part # ALT-OWBC), etc..., or A/F voltage output).
The Warning output can be used to activate warning light, enable fuel enrichment, shut down NOS or ignition, retard timing, etc.
Recording can be started by preset RPM value or switch.
Adjustable sample rates up to 100 samples per second.
Custom configurations available. Call for info.
Systems are upgradable.
All recorded data can be played back on unit or downloaded and graphed on a PC. PC NOT REQUIRED!
http://i155.photobucket.com/albums/s283/mseliz007/O2alert_graph.jpg
Download to a PC to view all data graphically. Software is Windows 98/NT/XP compatible. Allows viewing of any or all recorded channels, zoom and pan, overlay runs, smooth data, and printing of graphs.
So what do you think?
