Wanted: 14 Bolt Rear End
hey, looking for a 14 bolt rear axle in houston area......
this came under EVERY chevy from mid 70's to the mid 2000's on 3/4 and 1 ton trucks.
i dont want a dually rear end! single rear wheel axle only!
832-797-9114
832-797-9114
lol..... these are "slightly" stonger lol.....
10bolt<12bolt<9inch<dana60<14bolt
14 bolt is stronger in stock form than any other diff i know, short of a dana 80 or 2 1/2 ton rockwell axle.
it has a pinion support, bigger axles than a 9 inch or a dana 60, and is full floating. disc brakes are easy on them, and there is a large aftermarket following, just because no on breaks these things. they were one of the General's great made peices, and they went under EVERYTHING. trucks, vans, flatbeds, duallies, suburbans. you name it, if its chevy, full floating rear end, its 95% chance its going to be a 14 bolt.
I read they weigh close to 500 lbs. I would believe it. My 93 C2500 Suburban has one. The drum brakes on it are freaking monsters. Look at a 10-bolt, then a 12-bolt. See how puny the 10 bolt looks? That's what happens to a 12-bolt when you put it next to a 14-bolt.
TT-TECH Veteran
And that can be changed though. Although a direct bolt in is the easiest, but sometimes you take what you can find etc...Good luck. And for the guy asking why we haven't put these in F-bodies yet well they have no provisions for a TA and they are HUGE! I dought they would fit with out a lot of modification to the tunnel and that is if you could get a TA mounted some how.
it would be retarded trying to get one of these to fit in a car. they are freakin huge.
i would doubt you can swap a semi float to full float due to the spindles missing and everything else involved.
14 bolts are 8 lug. ill be ditching all of the stock drum brake stuff anyways, and going disc.
Are you looking for a fourteen bolt full floater or the ligher semi floater. All of the full floaters are for 3/4 and 1 tons. You could get a light duty 14 bolt that was available is select z71's and heavy half trucks. These are off the six lug variety. If you need a full floater 8 lug shoot me a pm I have just what the DR. ordered.
brian is our axle guy in houston area over on the truck site...pm him and he can get or build you anything you want...he is axisT6 on the site...he found me a 14 bolt 9.5" 6 lug axle for less than $300....
Trar:
pronounciation:
"Tuh/RaWr"
noun.
an abomination, or abortion of a vehicle that is a car body mated to a truck chassis. usually found in lower class neighborhoods, or "trailer parks". normally these lower class peoples or "rednecks" find these vehicle appealing. much to the dissapointment of the other human race, it is not.
ok enough hijacking my wanted thread.
STILL NEED A 14 BOLT FULL FLOATING 8 LUG, SINGLE REAR WHEEL AXLE. 100 DOLLAR REWARD
pronounciation:
"Tuh/RaWr"
noun.
