5.3 Vortec in older car..... more power...
Old 12-28-2007, 05:58 AM
chevy355's Avatar
Default 5.3 Vortec in older car..... more power...
Hi I have bought a 2006 5.3 Vortec that I plan to have installed into an older car. The guy I got it form have done all the wiring and computer reprogramming of the computer for my axle ratio and tire height. It is also programmed to run on 95 octane. I am planning to install headers and dual 2,5inch exhaust. K&N air filter and electrical fans.
How much power can I expect to have?
And I am also flirting with the thought of how I can make more power in the future.
Lets imagine I`ve got a $2-3000, how can i make the most power with my money? Cam, Heads, Supercharger, Turbo? (And please don`t say put in a 6.0L or nitrous, I`ve got this engine and plan to use it, will get a 6.0 next time, and since I live in Norway theese engine aren`t as easy to find over here)
I would still like to use it on a dayly bases in the summer here in Norway, so I can`t have something too extreme, and would like to have good torque down low as well.
Any Ideas? Thanks
Old 12-28-2007, 07:38 AM
LS1MCSS's Avatar
For 2 to 3000 dollars, you won't even get close to a turbo or supercharger setup. The best bet would be a cam, intake, throttle body, and have some port work done on the heads.
Old 12-28-2007, 12:38 PM
67rsss's Avatar
Depending on what you are after, you may find the 5.3 is perfect the way it is. I would fully expect you to exceed 300hp, which is a nice, comfy number. If you want more power after that, MC is right, you need to look at Cam, intake, head-work. Leave some cash on the table for some tuning as well, you can pick up a bit of HP just having the engine tuned. You didn't mention what older car you are using, that will make a big difference on what you should expect on the butt-dyno. That 5.3 will move a 5K lb truck pretty nice, it will really scoot in a 2800lb car.
Old 12-28-2007, 01:18 PM
LS1TECH Sponsor
Schwanke Engines's Avatar
We have 5.3L packages making anywhere from 350 to 425 hp. I would say your best bet would be a cam/spring/tune package. This would make the most sense. I don't think heads are going to be a good use of money, especially if you still want to retain low end power.
Old 12-28-2007, 02:28 PM
chevy355's Avatar
Default Going into...
either my fathers 81 Chevrolet Silverado Pick up lightest version with 3,23:1 rearend and 27 inch tall tires, or a 1972 Pontiac LeMans with 3,73:1 rearend and 27 inch tall tires.
Old 12-28-2007, 03:30 PM
67rsss's Avatar
The LeMans would love it!
Quick Reply: 5.3 Vortec in older car..... more power...
