How hard is removing the rear bumper?
Old 12-28-2007, 03:32 PM
Raise's Avatar
Default How hard is removing the rear bumper?
How hard is it to remove the rear bumper? If its something I can do myself, can someone walk me thru the steps? Thanks
Old 12-28-2007, 03:37 PM
blackbyrd's Avatar
its pretty straight forward on the ta's but i havnt done it on a camaro you will have to remove the tail lights and berger i would imagine though you might have better luck with this in the bodywork section.
and try a search for bumper removal there was a thread not long ago i think when someone was asking about this for a firebird they should be basically the same minus your tail lights and filler panel
Old 12-28-2007, 07:22 PM
Trev_SS's Avatar
Raise know what are you doing man you just cant make up your mind can you!
Old 12-28-2007, 11:57 PM
phoenix305's Avatar
down inside the quarter panels there are like 4 bolts, then under neither the bumper are a couple of push in clips, then there are a couple of screws in the wheel well. Thats as much as i can remember off the top of my head. Its not to bad to take off the hard part is getting it back on. might want a friend to help out with that.
Old 12-29-2007, 07:44 AM
Raise's Avatar
huh? what are u talkin about? who r u?
