ANy flow or dyno # on Patriat Heads
Re: ANy flow or dyno # on Patriat Heads
Gotta set on their way (Stage II's) and gonna mate it with a Furtal 226/230 cam (113 LSA). Should have it on the dyno on July 12th. I have all the bolt ons w/ big clutch and 4.30s so I am very curious how much power it will put down.
Best heads for the money, without a doubt.
someone get some damn track numbers with these heads LMAO. I wanna see a full bolt on car with a 224 cam or bigger dyno these heads also
I was talking to the guys at Texas Speed and they flowed TEA's stage 2 and Patriot stage 2 and they both flowed 296 intake and 220 exhaust. If you buy the 5.3 heads from Patriot they have free shippping and they will buy back your stock heads for $200. Patriot will also clean up the chamber, primarily under the exhaust to lower the compression from 11.0 to 10.7. This also increases flow 12-15 cfm on the exhaustr side making them better than the TEA heads. Imagine 235 exhaust flow. Sweet.
these were my 5.3, 11.1CR, stage 1.5 TEA heads flows
- Exhaust ----Intake
.100----51.7----70.2
.200----111.2---138.6
.300----167.6---201.1
.400----216.3---250.9
.500----248.0---282.5
.550----258.5---294.5
.600----265.6---302.2
yeah the exhaust side is about 20high cause they use a pipe, but that would put TEA's exhaust in the 235-240range without pipe
shipping was 25bucks or so and a 200buck core charge
im not putting down Patriot one bit here. Im glad to see friggin heads for 1k! Bout dang time Patriot, TEA, and AS are the best bang for buck heads I think. All within 200bucks of one another. Patriots new, so i cant want to see some track ET's this fall! But like I said, anyone that can sell stage 2 heads for roughly 1000-1500bucks is ok in my book MUAHAHA
6600 rpm clutch dump of death Administrator
I tried emailing patriot. The email address was no good.
----- The following addresses had permanent fatal errors ----- <gcampbell@patriot-performance.com>
(reason: 550 User gcampbell@patriot-performance.com not found.)
----- Transcript of session follows -----
... while talking to mail.patriot-performance.com.:
>>> RCPT To:<gcampbell@patriot-performance.com>
<<< 550 User gcampbell@patriot-performance.com not found.
550 5.1.1 <gcampbell@patriot-performance.com>... User unknown
The website has no working links, and they don't have a phone number you can call.
