Aftermarket Exhaust Question
Old 12-28-2007, 07:25 PM
my bandit's Avatar
Default Aftermarket Exhaust Question
i have a 1999 trans am and im going to order slp loudmouth 2 mufflers and i dont know of i have order 1 or 2 of them. i am keeping the stock pipes and im going to just install the mufflers and tips for now and get new pipes later. so can anyone tell me if i have to order 1 or 2 mufflers. thank you
Old 12-28-2007, 08:30 PM
chavez885's Avatar
1 muffler if you're using stock exhaust i believe
Old 12-29-2007, 03:15 AM
bryan04h's Avatar
when you order the lm2 you will get one straight through muffler that will connect after a 12" pipe off the y pipe..that is it brother
Old 12-29-2007, 07:11 PM
my bandit's Avatar
so i only need to order 1 of them. ok. also do the tips make a difference in the sound? last question where do you get the tips b/c slp online does not sell them. i want the dual/dual tips.
Old 12-29-2007, 07:46 PM
andrew69_04's Avatar
ummmm..... are you planning on taking your old crossflow style muffler off the back first?
Old 12-30-2007, 02:11 AM
waldershrek's Avatar
No the tips do not make a difference other than your personal appearence preference. If you want the DD tips you will have to check the classifieds here and ebay. You might be able to score a whole DD setup for pretty cheap and then just insert your LM2 resonater
Old 12-30-2007, 02:30 AM
bryan04h's Avatar
yes only 1..like the above post, the tips are just a preference...you can pick up the tips from a lot of sponser websites, ws6store.com, lmperformance.com, speedinc.com, byunspeed.com so forth and so on...you can mix and match as long as the size requirements are met
