Vibration after SLP LM1 install
Old 12-28-2007, 08:31 PM
texas99Z28's Avatar
Default Vibration after SLP LM1 install
I recently had SLP's LM1 catback system installed on my 1999 z28(A4) When in drive at a stoplight, I'm experiencing some vibration, and am now hearing squeaks around the rear hatch. My nephew has a 2002 Formula w/ LM1 and has vibrations also. Is this something normal with the LM1, or bad install?
Old 12-29-2007, 03:13 AM
bryan04h's Avatar
lift it up and make sure you don't have any exhaust leaks where the clamps are, see if all the bolts are tight as well
Old 12-30-2007, 02:35 AM
waldershrek's Avatar
Did the kit include any new hangers?
Old 12-30-2007, 07:32 AM
bryan04h's Avatar
i don't think the slp catbacks come with hangers..atleast when i had one it didn't come with one, it just reutilizes the existing ones
Old 12-30-2007, 11:59 AM
LS1>girlfriend's Avatar
i vote bad install, my LM1 never made a sound other then the beautiful sound of the world coming to an end.
make sure all the bolts are tight and nothing is binding.
Old 12-30-2007, 08:24 PM
slayerized6's Avatar
sounds like a hanger maybe loose or something. just tighten that **** up
Old 12-30-2007, 09:17 PM
dmcgill's Avatar
My LM2 came with new hangars, and after the install I experienced the same vibrations/noise. Your exhaust is probably touching the chassis somewhere causing the noise at idle. That's what happened to mine...it just needed to be readjusted.
Old 12-31-2007, 07:20 AM
bryan04h's Avatar
i never had a problem with my exhaust making vibrations, nonetheless i don't have a catback anymore...hmm i honestly don't think mine came with any hangers, maybe i got screwed...still put it in there using the stock hangers tho lol
Old 12-31-2007, 07:44 AM
Alt
Alt's Avatar
I have the same vibration on both my 95 v6 and my 2000 SS with the LM catback. I still have not found what in the hell it is. It sounds similar to a heat shield rattling but I can't recreate the noise on a lift only on a slight incline. PITA to find this but once I do I'll be sure to make a thread about it.
