foreverzero
12-30-2007, 07:51 PM
Here's a list of a few easily forgot mods
Dragstrip mods (next time your going to the strip try these)
1. Spare tire and jack removal- all together it weighs 37 pounds, WTF GM?
2. Remove back seats (few bolts, easy)
3. 1/4 tank mod- easiest mod, run under 1/4 of gas, with the gas prices, your tank should already be there...
4. !Floormat- sometimes the floormats ride up under the pedal, preventing it being "floored" just leave it at home
Tune up mods (next time you do the tune up)
1. Seafoam or auto-rx, stop putting this one off, your engine needs to be cleaned! Removes sludge and build up, even cleans fuel lines if you do the whole treatment.
2. Synthetic oils- a little more expensive than normal oil, but IMO better. Royal Purple claims its dyno proven to add horsepower. They also have gear oil for the rear diff. might be a good time to change that one too.
3. Indexing plugs- now I haven't tried this, but supposily this helps. Mark the side on which the "open end" of the spark plug faces. Install them as you normally would, except when the plug is hand-tight (that is, you've screwed it in without a ratchet as far as it'll go), use your ratchet to tighten the plug until the open end of the plug, faces the intake side. Hey every little bit helps!
DD mods
1. Free ram air mod- done by removing the plastic from the bottom of the airbox so more air flows into your intake. Just make sure you leave the center "bar" or your filter will not stay in place. http://www.installuniversity.com/install_university/installu_pages/freshman_year/free_ram_air_mod.htm
2. Throttle Body Port and Polish- you will notice this one, this is by far the best mod you can do for the buck. Its free, all you have to do is read a write up and own a dremel. Also make sure you do the TB bump stop mod. This is done by grinding the bump stop on the side of the throttle body, making it actually open up all the way.http://www.ls1tech.com/forums/showthread.php?t=520845&page=2
http://www.installuniversity.com/install_university/installu_pages/sophomore_year/tb_bump_stop.htm
3. TB bypass- done by removing the hoses that connect to the bottom of your throttle body, and connecing them together. http://www.installuniversity.com/install_university/installu_pages/sophomore_year/tb_bypass.htm
4. Short Throw (for the 98-02 M6 cars) here's a cheap short throw for $25 shipped, I have one and I'd pay much more than that http://www.ws6project.com/user_stor/catalog/product_info.php?cPath=235_79_34&products_id=628&osCsid=90da291227c82597bfa896f49c859b7b
just a liitle quick reference to help :D
DD mods
