RPM Stage 5 4L65E For-Sale
Good for 1000 HP!
RPM Stage 5 4L65E
Media blast transmission case
RPM sleeved input drum
RPM 3-4 clutch pack
RPM sunshell with laser welded collar and bearing
Heavy Duty double caged 29 element sprag
4L65E low roller clutch
Billet 4th gear servo
Transgo HD-2 shift kit
Corvette Servo
Wide 2-4 band
Updated aluminum accumulator piston
Bushing kit
new shift solenoids
new GM valve body spacer plate
GM 5 pinion planetary gearsets - front and rear
Seal & gasket kit
Filter
Set end play
http://www.rpmtransmissions.com/fbodypricing.html
Call or Email for pricing.
RPM Stage 5 4L65E
RPM 3-4 clutch pack
Corvette Servo
Wide 2-4 band
Bushing kit
new shift solenoids
Seal & gasket kit
Filter
Set end play
