View Poll Results: How much power have you made with a T4 T76
Voters: 14. You may not vote on this poll
What is the most power you have made with a T4 T76?
My old Shop car with a 370ci engine and the TC76MPS turbo made 770rwhp on 15lbs of boost. Still alot left in the combo. Last I had heard Billy had put a set of bigger injectors on and was turning up the boost to see what the turbo had left in it. I havent heard about any new numbers yet.
Nice #'s. If you can, please hit the vote button to capture the results. Thanks Josh.
I think that's close to the same as a 76GTS except it has a slightly larger turbine minor diameter. The 76GTS turbine exducer is 2.96" (85 trim) while the R-trim is 3.20" (100 trim). I'm not sure what other implications go along with having a 100 trim and if it's even better. One thing is for sure - you HAVE to use a 3.5" or bigger downpipe with the R trim. Zombie proved that one.
Also, I thought that since R came before S in the alphabet (last time I checked), then the R wheel would be smaller. But that's neither here nor there.
Mike
Mike
Mike
Mike
Mike
Mike
