New cam.. Overloading with gas??
Ok guys, first pretty day I have had since I got my car back. I finally got to take it out today! So, I was sitting at a red light and opened it up when I pulled out, everything felt fine. I looked in my mirror and seen a hazey look that was no doubt smoke and I dont believe it was from the tires.. its just like 45 here. I know with carb'd motors, its typical to overload on gas, but could this be true with FI cars too? .. My car never smoked before the installed, at all.
Note: I am also throwing a code because I have 2 o2 sensors going out. When I got the final tune last Thursday, they were still working, just reading slow. Could this possibly be my problem also?
Thanks,
Ryan
Thanks,
Ryan
Not sure where you had it done, but replace the O2 sensors and take it back to get retuned. You need the sensors in working order to nail a tune, and it seems like yours isn't.
Yes, the front 2 are the ones reading gasses for the ECM to adjust for.. the rears are only telling the ECM that the catalytic convertors are working.
You can swap your rear ones to the front, and vice versa, and delete the rear O2 codes if you still have them.. or you can go to a parts store and order new ones.
