SPANKY LS1
06-30-2003, 05:10 PM
I am in the middle of installing my 12 bolt, and tried wire-tying the factory brake lines to the housing, and it looked like crap. What did you do? I bought some 3/16" brake lines, installed the correct fittings and bent it so it more closely followed the curves and contours of the housing, then wire-tied it to the housing. Does this sound OK? Do you have any pics of yours or other ideas?
What did you do with the bracket that connected the brake lines on the rearend to the rubber brake lines that go to the body? I am thinking of mounting it where the vent tube goes, anywhere else?
What did you do with your brackets that the emergency cable mounts to (Kinda goes where the LCA mounts to the housing) With my relocation brackets, this bracket will no longer fit over the housing, how did you attach your emergency cables?
Any pics of completed 12 bolt installs would be helpful. Thanks, Shawn
