Which Procharger F series model is for the LT1
Old 01-01-2008, 09:19 PM
wicked_95z's Avatar
Default Which Procharger F series model is for the LT1
and fits in the P1 bracket?
Old 01-02-2008, 05:01 AM
EPP
EPP's Avatar
The F1 and F-1A are the ones that have the same volute diameter as the P series. These blowers are approx .38 longer, and some people report having to do a little grinding to get them to fit on the LT1. Other people have said they bolted right up. Bob
Old 01-02-2008, 07:41 AM
wicked_95z's Avatar
What the deciding factor between the two? I have read the procharger site but I have already made one mistake basing my decision off of that info. What's the going rate for those bad boys?
Is it bad if I had to grind the block to get the P1 to fit?
Thanks, Bob
Old 01-02-2008, 09:35 AM
EPP
EPP's Avatar
Thumbs up
Thanks, Bob
No, it's not a problem at all. Thanks. Bob
Old 01-02-2008, 10:19 AM
Ponyhntr's Avatar
Go with the F1A.
Old 01-02-2008, 11:30 AM
SRZ
SRZ's Avatar
Grinding the block to get the F1 to fit. You'll also need to grind down the 2 veins of the ABS bracket unless you removed it already. Not much to it.
Old 01-02-2008, 08:23 PM
EPP
EPP's Avatar
Thumbs up
Originally Posted by Ponyhntr
Go with the F1A.
Yes indeed! Bob
Old 01-03-2008, 02:03 PM
ramair96ws6's Avatar
go with the D1SC I have one for sale that way i can get the F1A
Quick Reply: Which Procharger F series model is for the LT1
