Drag Racing Tech - Aftermarket Tach - Where did you install them?
fasttagurl
01-02-2008, 08:07 AM
I still have my stock tach and am getting an aftermarket one from Autometer. (To read RPMs by the hundreds) Any NHRA or "Street Legal" rules/regulations on where I can or cannot mount these? :confused: Would this still be classified as "stock appearing"? I have the NHRA book but it is not clear about guages. If you have pics where you mounted your tach, let me see them! (This will be without a shift light or RPM recorder.)
Duffster
01-02-2008, 09:00 AM
Here is my first location. . .
http://www.youtube.com/watch?v=RNMOa-4MHH8
My second after the first got stolen (I left my windows down for 8 freakin' minutes in public!!!)
http://i10.photobucket.com/albums/a101/Duffster-01Z/Tach%20Socket/DSCF66671.jpg
Pro Stock John
01-02-2008, 11:13 AM
I have mine bolted on the right side of the trim ring, but were I do redo it I would put the tach on the steering column.
Old pic of Formy (front cage has been redone):
http://psj.ls1tech.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=163&g2_serialNumber=2
Z06kern
01-02-2008, 12:09 PM
I welded a tab on my cage and mounted it below my switch panel.
http://i78.photobucket.com/albums/j102/Z06kern/MVC-006F-18.jpg
BTLFEDSS
01-02-2008, 03:27 PM
This is where mine is and i relocated the shift light to the colum
BTLFEDSS
y2k_ta
01-02-2008, 03:59 PM
Mine is mounted similar to PSJ's...
http://www.scottsrides.com/dash_aluminum.jpg
BJSS25
01-05-2008, 12:06 PM
Here is my tach location.
Klive
01-05-2008, 12:31 PM
do you run an NHRA class? if not then don't worry so much about what the rule book says other than safety items
RAGENZ28
01-05-2008, 01:55 PM
I don't have a photo but I took off the drivers window visor and screwed the bracket into an existing hole, it hung from there and was out of the way and very easy to see without taking your eye off the road.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
