Alternator Squeak Help!!!
Old 01-02-2008, 08:44 PM
my bandit's Avatar
Default Alternator Squeak Help!!!
my alternator is squeaking. at first i thought it was the belts b/ci hadnt replaced them since i got the car but after i replaced those it still squeaked so i found out that a broke the bearing in the pully and i was wondering if their is anything i can do instead of buying a whole new one
Old 01-02-2008, 10:44 PM
Josh Nickelsen's Avatar
Take it to someone in your area that can rebuild alternator's. They can put new bearings in for you and it shouldn't cost a whole lot. I would say at the very most it would be $50 but I think they will do it cheaper than that.
Old 01-03-2008, 04:00 AM
bryan04h's Avatar
or buy a new high output alternator
Old 01-04-2008, 04:30 PM
my bandit's Avatar
would i be able to do it myself?
Old 01-04-2008, 06:02 PM
Closed ex-Sponsor Account
autotrix's Avatar
I think so, if you could find a rebuild kit. Might as well replace or have and extra voltage regulator lying around.
Old 01-04-2008, 06:15 PM
Shooter_Jay's Avatar
are you sure it's your alternator? Mine was making a nasty squealing noise sometimes on startup that sometimes goes away. I think what it is is the...forgot...search...oh yeah, the AIR system check valve or whatever it's called. I was looking into fixing it, but it stopped making the noise so I haven't done anything about it.
Old 01-04-2008, 09:55 PM
my bandit's Avatar
no bc the more gas i give it the louder it gets so it still squeaks as i drive and its annoying as hell
Old 01-04-2008, 11:22 PM
oh, yeah I think mine went away if I goosed the throttle as it warmed up.
Old 01-05-2008, 01:48 AM
Gaunt's Avatar
You said you replace the main serpentine belt, but did you replace your AC belt?
Mine was squeaking and for the life of me kept pissing me off... finally just looked down and realized I forgot about the tiny *** belt in the bottom lol
Old 01-05-2008, 06:35 PM
my bandit's Avatar
yea i just replaced both of them and the alternator and now theres just a mild squeak when i start it up but if i rev it up it will go away so i think the pullies need to be oiled now but it was definately the alternator
Old 01-05-2008, 07:04 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
It could be the idler pulley as well. The factory GM idler pulley is garbage. Mine is squeaking and chirping as well. The one on my wife's 9-7x (same as the trailblazer) had to be replaced at 30,000 miles for the same reason.
Old 01-06-2008, 03:59 PM
my bandit's Avatar
i think that its the pully infront of the power steering resevoir
Quick Reply: Alternator Squeak Help!!!
