axles different from 93-02?
I recently slammed into the side of the curb trying to get around a tight turn quickly, and shattered the wheel and bent the axle. The local pull a part place has a 94 firebird and a 93 camaro V6 i believe, will the axles out of those work in my 4 channel rear end? if not where could I get a new one for not a ton of money? are the axles the same from drivers and pasengers sides?
thanks in advance...
LS1Tech Premium Sponsor
the axles are the same length each side. the only difference will be 3 or 4 channel abs. a 3 channel axle will not work with a 4 channel rearend.... there is no reluctor wheel on a 3 channel axle. i'm not sure of the 3 channel axles have been machined for the reluctor, but if so, the you could just swap the reluctor wheel over from your existing axle.
4 channel axles are in 98-02 tcs equipped cars. you should be able to locate a good used one in the sales section. v6 and v8 cars are the same rearends.
I have a lot of low to no milage axels. they were out of low milage to no Fbodys I will give you a good deal. I Think I have 3&4 chanel. PM ME OR Email me carssnut@comcast.net
