Header install from the top
Old 01-03-2008, 05:48 PM
Texastransam's Avatar
Default Header install from the top
I just finished installing my pacesetter headers. The drivers side went according to plan, but on the girlfriend side I had to drop it in from the top. We took off the valve cover and it dropped right down.
Anyone else ever try this??
Old 01-03-2008, 06:02 PM
Tainted's Avatar
i put mine in through the bottom no problem on both sides. what was wrong with going from the bottom?
Old 01-03-2008, 06:14 PM
stangkiller2005's Avatar
wait a minute...u got an LT header on! coming from the top? on the passenger side??? i had no idea u could even do that! ive always done it from the bottom!
Old 01-03-2008, 06:35 PM
Tainted's Avatar
you can do it if you have everything out of the way but going from the bottom is so much easier
Old 01-03-2008, 06:47 PM
2001NBMZ28's Avatar
I've helped with 3 different header installs, all different brands - always from the bottom. SLP was the worst...especially on the passenger side.
Old 01-03-2008, 06:49 PM
allforspeed's Avatar
can it be done relatively easily in your garage? debating if this is a project i want to tackle flat on my back, heard the best way to put them in from the bottom without removing suspension is to put the car like 4 feet in the air. how long did this take you?
Old 01-03-2008, 07:02 PM
luis_ws6's Avatar
Just did mine last week, and I got to say its easier than I thought. I got hookers and Im glad I didnt pay to get them instaled. I just had to grind a little on the driver side like every said and the passanger just slid in with no problem. We did it with just 2 jack stands in the front. Took us about 4-5 hours. The hardest part I encountered was taking off my y pipe, cause we only had a grinder
Old 01-03-2008, 07:04 PM
pitbull14218's Avatar
what did u grind?
Old 01-03-2008, 07:06 PM
Originally Posted by pitbull14218
what did u grind?
probably the k-member.
Old 01-03-2008, 07:09 PM
my friend installed some PS on a V6 swap to V8 car(LS1) was a camaro, they claimed they had to dent the headers because the steering knuckle wouldnt go back on or something. Now they might just be dumb ***'s but i was just a little concerned because i plan on getting some PS's and everyone seems to love them. thanks.
Old 01-03-2008, 07:10 PM
luis_ws6's Avatar
Yea, thats what u call it
Old 01-03-2008, 07:13 PM
DaveX's Avatar
I tried installing my pacesetters from the top with the heads off. The passenger side dropped right in but the drivers side would not go in from the top. I wrestled with it for about an hour and even shaved the emboss on the side of the block. I never took the steering linkage loose but it didn't look like that would help.
Old 01-03-2008, 07:16 PM
luis_ws6's Avatar
Yea removing the knuckle was the last thing I would have done, but my hookers fit fine. Sure u have to fight with them but just take ur time. Lift the car higher if needed, I broke a spark plug so it just gave me an exuse to do my plugs and wires
Old 01-03-2008, 07:28 PM
I thought u need to remove the steering knuckle to install pacesetters? i heard its only like 4 bolts. I hear how its easy and i hear how it takes 7 hours, and then people i know had to beat on them, i want them but i dont see how its easy and hard!
Old 01-03-2008, 08:56 PM
luis_ws6's Avatar
I didnt have to remove it. just some grinding. if u do remove the bolts make sure it bolts up the same way cause it will mess with your air bag system.
Old 01-03-2008, 09:01 PM
5w20's Avatar
i guess nobody caught that one
