Sponsored by: DashLynx
Summit Racing Z28 decals?
Old 01-04-2008, 11:21 AM
Kamauxx's Avatar
Default Summit Racing Z28 decals?
Anyone try these decals out?
Wondering if they are double sided taped and if so, how well they hold?
Old 01-04-2008, 11:24 AM
Mark IXZD 150's Avatar
They're not decals. They're OEM emblems which are held on with posts. You can cut and grind them off and add a 3M adhesive tape to put them on without having to drill holes in your car.
Old 01-04-2008, 11:43 AM
Summer's Avatar
get them.... get them NOW!
Old 01-04-2008, 02:09 PM
Kamauxx's Avatar
They have the posts ones on there, but the ones I posted are different, they don't have the posts.
Old 01-04-2008, 02:14 PM
Kamauxx's Avatar
Did I miss something?
Old 01-04-2008, 04:38 PM
ls1leadfoot's Avatar
yeah they are on national back order
Old 01-04-2008, 10:58 PM
Kamauxx's Avatar
Yea, the site said they wouldn't ship till the 17th, just trying to be certain these are dbl sided tape versions.
Old 01-04-2008, 11:31 PM
Jakson's Avatar
Where do you see that? It says OEM 69 Camaro Fender badge, so Im pretty sure it has the posts. I got two new ones off ebay for $20 shipped btw.
Old 01-05-2008, 09:11 AM
Kamauxx's Avatar
On their site there is two different types. One has pics of posts, and says in the description it's bolt on, the other doesn't.
Here's the one that shows a picture of the posts.
Notice the difference in description and picture from the one I posted yestereday.
Anyway, you got them for 20 bucks, I'm sending you a pm.
Old 01-05-2008, 09:17 AM
irbs's Avatar
I have them on my car. They look good.
Old 01-05-2008, 03:34 PM
Jakson's Avatar
They both have posts. The one you posted there is for the grill, thats why it has the backing plate. The first ones you posted have posts on the back too, trust me.
Old 01-05-2008, 07:11 PM
Kamauxx's Avatar
Damn, so where the hell do ppl get these from? I remember someone saying ebay but all the ones I found there also have posts, and are EXPENSIVE!!!
Old 01-05-2008, 07:57 PM
01ssreda4's Avatar
double sided tape emblems stick well if you prep the surface.......it has to be CLEAN.
Old 01-06-2008, 09:12 AM
Kamauxx's Avatar
Can't find any!!!
Old 01-06-2008, 12:14 PM
Jakson's Avatar
If you want the 69 Z/28 emblems, you will have to buy the ones you see there. Then cut the posts off, buy some double sided tape and stick them on. I haven't seen anyone who sells them all ready to stick on...
Old 01-06-2008, 12:53 PM
GETGONE's Avatar
All it takes is a Dremel with a cutoff wheel and some double side 3M tape and hobby knife to trim the tape around the emblem. I put 69-72 SS emblems on my car and it only took a few minutes each to cut the posts off and put the tape on.
Old 01-06-2008, 04:34 PM
Kamauxx's Avatar
So, is there any specific type of 3m tape I should get, or all they all the same? I don't want the tape to melt in the 100+ degree heat of the summer. Also, how much does the tape run?
Old 01-06-2008, 07:45 PM
GETGONE's Avatar
I picked up some 3M exterior double side tape from Home Depot. It's wider than the automotive trim stuff which is what I wanted for my SS emblems. It was like $4 for a roll that I was able to do all 4 pair of emblems plus have over half a roll left.
Quick Reply: Summit Racing Z28 decals?
