Stereo & Electronics - AudioBahn AS65V
mezmerize1
01-04-2008, 11:44 AM
are they any good? i was going to get type R coaxials but i can get the audiobahns considerably cheaper. they have the same rms but the peak power of the audiobahns are 200 watts as opposed to 300. The audiobahns also have a higher decibal rate. the audiobahns are rated at 94 and the type-r's are rated at 87. if I get an amp with an rms of 100 watts but the peak is 300, will that mess up the speakers?? TIA
J-Bru-Ha Z-28
01-04-2008, 12:00 PM
I love Audiobahn, I have had three sets of subs from them with nothing but good things to say. In my experience they under rate their power capacity, I would think you would be alright.
mezmerize1
01-04-2008, 03:43 PM
i was looking at amps to power my speakers and i need to get a 4 channel, 100 watt rms amp. i was looking at a CRUNCH PZI1004 mainly because its cheap. i haven't really heard much about this brand, should i stay away from it?
KEE AUDIO
01-04-2008, 05:15 PM
How cheap is cheap? I may be able to get something for you within your budget. Let me know if I can help!!
mezmerize1
01-04-2008, 05:45 PM
I have 375$ left for speakers and amp, etc. i spent $200 on my HU. i'm going to be getting Polk Audio db6501 component system for my front speakers which is $129 new from amazon. Then i'm deciding between the alpine type-r coax speakers for the sail panels or the audiobahns. the type-r speakers are 50$ on amazon and the audiobahns are $25. I probably wont get anything for the hatch speakers for now because they dont really do much. I actually just realized a couple days ago that my hatch speakers were disconnected and i didn't even notice it. if you could help me set up something for the money i have, thatd be great too.
EDIT: I forgot to say that the Crunch amp is only 75$.
mezmerize1
01-05-2008, 11:09 AM
i was searching around online and i came across the Audiobahn AMD60Q and the Audiobahn ABC6002V. i can afford both and the component set runs at 200W rms with a 4-ohm impedence. But the midbass speakers say that they are 200W rms/ pair. does that mean that its 100W rms per speaker? It also says that it has a 3 ohm impedence. would these be difficult to hook up to one amp? TIA
mezmerize1
01-06-2008, 12:18 AM
anyone??
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
