Need new GM stock muff/cat back?
Where can I buy a new GM stock muffler and over-the-rear-pipe for a 99 F-body?
Is the installation of the over-the-rear-pipe a PITA?
...finally fead up with all after-market cat- backs - need QUIET muff.
Thanks.
Thanks.
I pulled my original out without too much problem and without needing to cut anything. I did have to pull the passenger side of the axle down though after disconnecting the shock on that side and removing the one rear spring. It can be done.
