t56 rebuild......what level?
need a little help. i have no idea which level i should be looking at. level 3 sounds like what i need, but i don't want to spend for a level 3 when i should be on a 5.
car is fbody 600rwhp, twin tex, may spray somewhere in the future to somewhere around 750, but no spray yet.
i guess part of the problem is i'm not sure what the big differences are. if i were to go level 5, someone said viper shafts were breaking and i needed to spend extra to change out to a different yoke or something? i'm sure i don't have that exactly right, but does that make sense.
level 3/4/or 5?
car won't be raced at a track much, but some, driven fairly hard though when i drive it. i like to bang the gears hard on the back country roads
rob
level 3/4/or 5?
rob
No one that we have ever built one for has broken a viper shaft. I have a 99 GTS that made 1602 and went 8.29. Never had any shaft problems with it.
I would do all of the standard upgrades like billet keys, bronze pads, steel fork as well as the viper input shaft and viper output shaft conversions.
It all depends on who you are going to use as to the cost as well as the warranty they offer.
Amber
Amber
We all have different packages and they are all different so you have to look at the company to decide what is included. Either way there are plenty of us out there to help. Just make sure you use who you feel comfortable with and make sure they offer you a 1 year warranty like ours.
Amber
Amber
Level Three - EXTREME Viper T56
Bronze 1-2 fork pads
Bronze 3-4 fork pads
Billet 3-4 syncro keys / upgraded springs
Carbon Fiber blocker rings
Steel 3-4 shift fork
New 1-2 slider
New 3-4 slider
Our NEW Custom Shortened Viper Mainshaft
Larger Output Shaft Bushing
Larger Seal
Custom machined tailhousing
30 spline slip yoke
New U-Joint
Modified Speed Reluctor
so something like this is fine? or should i be looking at a level 4 or 5
New 1-2 slider
New 3-4 slider
Larger Seal
30 spline slip yoke
New U-Joint
i'm not over 700 yet, but there is a chance down the road in the near future.
amber,
did you use to live in charlotte? checked your site out. it's got to be you. hope all is well with you and joe.
happy new year.
amber,
happy new year.
That is us. I remember you Rob. Talked to you alot when we were there. If you want over 700 go with that package. Mine is more expensive since he is offering the discount. My rebuilds come with a full 1 year warranty would be the only difference. Good luck with whoever you choose.
Amber
Amber
if you were to do the viper input and output shaft conversion, does that mean you would have to change your clutch as well? i have a mcleod twin and i don't want to spend another thousand on a clutch setup. i have a pst driveshaft with a 1350 slip yoke off the tranny, would the new viper yoke be able to fit the pst?
tranny
I second that! Amber knows her **** plus my buddy had his sent there and it's bullet proof. I guess it's nice to have the viper internals but like amber told me good luck with the gear set. I will be sending mine out in about 2 weeks for the stage one rebuild. dude call them since they just want to make sure you are getting what you are paying for. She'll explain everything and every package. YOU ROCK AMBER!!
LS1TECH Sponsor
We offer a 12 month warranty on our transmission as well. All warranty info is included in the package we send back out. I don't think Joey has it posted on our site, so if anyone needs to see the details just shoot Joey@Tickperf a pm.
Also, we only offer 3 basic packages to keep confusion to a minimum. Most builds don't need any other items than we include in our packages. If something extra is necessary, like a 5-6 slider for example we just call the customer and let them know that we recommend that they replace that also. By doing it this way, no one orders a package that has items they do not need.
Lastly, putting a warranty on a trans based on rwhp is difficult to do. A 2700 lb. Rx-7 with an LS1 swap would be much easier on the trans than a full weight f-body. Weight, driving style, rpm at launch, tires, etc. all come into play. Give us a call or shoot us a pm and we will steer you in the right direction!
