*New Year Special* TTP Equalizer & Punisher Camshaft Specials
Stage 3 Equalizer/Punisher Cam Package
# TTP "Equalizer" V.3 Camshaft OR TTP "Punisher" V.4 Camshaft
# Patriot Xtreme Dual Springs, Spring Seats, Titanium Retainers, Valve Stem Seals
# TTP Custom Chromoly Hardened Pushrods
# LS2 Timing Chain
# 6 Qts Royal Purple 5w30 + Filter
# All GM OEM Gaskets/Bolts necessary
# Installation
# Full LSx Custom Tune includes Dyno Time & Part Throttle Tuning.
$1850 98-02 F-Body
$1825 04 GTO
$1750 05-06 GTO (Reuse LS2 Chain)
$1950 97-04 Vette
$1875 05-06 Vette (Reuse LS2 Chain)
$1950 07-08 Vette (Replace Timing Sprocket with LS7 for 3 Bolt Cam)
Trucks please call.
- Add Powerbond U/D Pulley Set w/ Belts $275
- Add 160 Thermostat Housing $50 Installed
- Add Melling Select High Volume Oil Pump $165 (Add $95 install to GTOs & $35 to other vehicles)
- Add Meziere Electric Water Pump $650 + $75 installation with relay wired to keyed ignition switch (Run waterpump with ign on, vehicle off)
- Add Kooks Custom Headers - Priced per application
The shop is unusually busy for this early in the year, so we are backlogged about a week. To setup your appointment, we will require a deposit of $900 towards parts (C/Cs over phone accepted). The entire installation with tuning takes 2 business days.
Give Billy a call @ 973 365 2270 to discuss packages.
- Matt
# LS2 Timing Chain
# Installation
$1850 98-02 F-Body
$1825 04 GTO
$1950 97-04 Vette
Trucks please call.
- Matt
