Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Info 799 heads!
Old 01-05-2008, 04:39 PM
litle88's Avatar
Default Info 799 heads!
Hey does anyone here have any info on 799 heads, some say they are just like the 243's?
The reason I ask is because I can get these heads for free!
Is it worth it?
I did a search but it was pretty old and nothing conclusive!
Thanks
Old 01-06-2008, 12:45 PM
xpndbl3's Avatar
if they are free grab them If you don't want them, turn them in for scrap weight.
Old 01-06-2008, 02:27 PM
Top Fuel's Avatar
I believe 799's are 4.8 heads
Old 01-06-2008, 02:35 PM
Top Fuel's Avatar
i just did a quick search on them and I can conclude what the hell they are either lol
Old 01-06-2008, 02:36 PM
litle88's Avatar
I dont think so cause 799's were used on Ls2's and in some cases C6's and TBSS's had 243's and 799's. sometimes one 799 on the left and 243's on the right!
my brother has an 07 tahoe 5.3 with 799's!!!
and he's the one giving them to me.
thanks TOPFUEL, anyone else?
Old 01-06-2008, 11:46 PM
THEE PEWTER Z™'s Avatar
ttt would love to know....
Old 01-07-2008, 01:07 PM
14 Second Truck Club
mzoomora's Avatar
Do a quick search on performancetrucks.net, they might have something on there. I believe they are the ones that came on the higher output 5.3's with the aluminum blocks. They should be smaller chamber (like an older 5.3 head) but with LS6 ports.
Old 01-07-2008, 01:14 PM
02TransAm/Batmobile's Avatar
They are the same as the 243's. In some of the 2007 Corvette's they switched from 243's to 799's. It is the same castings but were stamped with 799's because they are from Mexico some believe. I'm not sure about that but some have reported seeing one 243 on the left and a 799 on the right or vice versa. Hence the quote, "It pulls harder to the left!" GM wouldn't put mismatched parts on a Corvette or TB so, same as the 243 but different number.
I'm guessing with your mods, you'll pick up about 20 horses. Mill the heads and pick up 5 more horses.
Old 01-07-2008, 01:16 PM
"243 vs. 799 heads talked to GM research tonight.
I talked to Bob (Gohard777) and Mr. X. There is no difference between the two heads. The numbers tell what original mold the casting came from. 243 mold was done at GM Research, the 799 mold is used by other vendors. The same vendor will have 243 and 799 molds. The numbers are just a GM system for when the mold was made. If a head had a problem it helps them track down where the problem started. The only difference between the heads is production variance. Case closed. Thanks to Bob and Mr. X. Mr. X machined the first 243 heads himself at GM Research."
Kinda like how Patriot Performance takes a 035 Raw Head and turns it into a 243 head.
Old 01-07-2008, 01:22 PM
litle88's Avatar
Awesome JAMES muchos thankyous!!!
Old 01-07-2008, 03:00 PM
xpndbl3's Avatar
what i don't get any thanks?
Old 01-07-2008, 05:38 PM
litle88's Avatar
Of course you do big guy!!
Old 01-07-2008, 09:15 PM
xpndbl3's Avatar
i'm STILL not going behind the wood shed for a random breathalizer test there mister.
Old 01-08-2008, 12:02 AM
litle88's Avatar
where do you prefer then ?
in the back of a squad car, the ones w/ the tinted windows ?
Old 01-08-2008, 02:37 AM
xpndbl3's Avatar
bring the cuffs, i'll bring the smile.
ick.
Old 01-08-2008, 09:36 AM
ONEBADWS6's Avatar
So Zeke how are you getting these for free? Hook a guy up.
Old 01-08-2008, 11:37 AM
1_bad_TA's Avatar
Can you get any other sets of these?
Old 01-08-2008, 12:15 PM
litle88's Avatar
They are off my brothers 07 5.3L tahoe he wants to do some cam and heads for it and I told him I WANT them.
Old 01-08-2008, 12:17 PM
1_bad_TA's Avatar
lucky bastard
Old 01-08-2008, 04:05 PM
litle88's Avatar
Originally Posted by 1_bad_TA
lucky bastard
HAHA
All I know is his azz better not back out on my azz
Quick Reply: Info 799 heads!
