Low oil light question
Old 01-05-2008, 04:43 PM
98LS1Formula's Avatar
Default Low oil light question
I just picked up a 98 Formula and I have an issue with the low oil light
When you turn the key to on without starting the car and the SES lights flash on and off sometimes the low oil light stays on once the car is started
I checked the oil level and its fine
Other times it shuts off before the car is started and stays off
So far it hasnt come on when the car is running just dosent go out when the car is started.........
Oil pressure is fine
I am thinking maybe the sensor is on its way out
Anyone else have any ideas?
Thanks!
Old 01-05-2008, 05:27 PM
NC98Z's Avatar
Have you ever seen one. Its a cork floating in the oil on a shaft. I wouldn't think twice about replacing it. No I'm not bullshiting you!
Old 01-05-2008, 05:30 PM
1badA3Z's Avatar
Mine had a short in the wiring,fixed the loose wire and it was fixed!
Old 01-05-2008, 10:21 PM
Medic/Z28's Avatar
I agree with NC98Z
