Porting an ls6 intake
Old 01-05-2008, 06:37 PM
shdybrady1988's Avatar
Default Porting an ls6 intake
Is it possible for someone to do it themselves. I always see people taking it to places to get it done. Is it really that hard?
Old 01-05-2008, 06:38 PM
jessedale98's Avatar
Real simple. No dont waste your time. You'll probly break it and there really isnt much gain to be had.
You dont see a lot of people doing it like u stated because there isnt much to be had, like I said.
you DO see people porting aftermarket intakes though. Just not a stock LS6
Old 01-05-2008, 06:46 PM
allthrotle's Avatar
You could port it if you want to but, its not worth the trouble. If you have it just throw it on. Most porting goes on with the aftermarkets like the fast. There is power to be gained if you port the fast.
Old 01-05-2008, 07:02 PM
turbogarrett's Avatar
If you have ported heads, it MAY help to port match the runners. If you have a dremel, a steady hand and some self control you won't ruin anything. I'm not expecting it to make much of a difference, but every little bit helps.
Old 01-05-2008, 07:12 PM
james562's Avatar
New Era ports them for I think 150 last time I checked, but the gains are marginal at best... Save the 150 for the 90/90 setup later on...
Old 01-05-2008, 11:19 PM
Restricted User
Zero4488's Avatar
Every little bit counts. Do what you can to make power with out buying the aftermarket manifold. I personally wouldn't try doing it myself....but if you think your up to it....knock yourself out....
