Can't pump gas in my new ride
Old 01-06-2008, 06:58 PM
MuscleCarZ28's Avatar
Default Can't pump gas in my new ride
Just picked up a 2001 z28 a week ago and when i tried to fill my tank up the pump stops as if it's full. I was able to hold the pump handle half way and it filled up, but super slow. Then i tried another gas station and it would not even let me hold the pump half way. So far i have only found one gas station that was able to work with no problems. Any idea how i can fix this?
anybody ever have this problem? I cant afford to go to these high price gas stations in san francisco,so i need to fix this and grab some costco gas@ 3.45/gal. (premium) everybody else wants 3.70-3.99 i need ever penny i can save =)
Thanks, Dan
Old 01-06-2008, 07:44 PM
sroach20's Avatar
you will eventually learn how to manipulate the pump handle to make it work.
Old 01-06-2008, 08:08 PM
nrs2420's Avatar
would it have something to do with the vent on the tank?
Old 01-06-2008, 08:11 PM
LivingCanvas's Avatar
By chance, did you have the key on(engine off) when this happened? Like if your listening to the radio or something?
Mine wont let me pump gas into it with the key in the on position. Drove me nuts till I figured it out
Old 01-06-2008, 08:24 PM
BlueBird346's Avatar
OMG im glad i dont live there. I pay 2.99-3.09 here in AL for premium. And i thought that was a lot. lol
Old 01-06-2008, 08:38 PM
Tainted's Avatar
its 3.30 here in fayettenam but raleigh and charlotte is only 3 bucks... stupid military town
Old 01-06-2008, 08:45 PM
Usasoc's Avatar
3.24 in savannah.
I hate gas prices.
I'm broke.
Old 01-06-2008, 10:11 PM
now that i think of it the one time i was able to pump with no problem i was by myself and most likely took the key out. I hope that's what it was and if it does work, does that mean all camaros are like this? thanks for the replys
Old 01-06-2008, 10:24 PM
99camarosupersport's Avatar
In all my time here I've never heard of this, hope that fixes your problem.
Funkster's Avatar
$2.66
Hooray for central Iowa?
Old 01-06-2008, 10:27 PM
Rushin's Avatar
$3.21 average in Montgomery, AL.
Old 01-06-2008, 10:41 PM
vettehardt's Avatar
Every once in a while I have a problem with the pumps. I think it has something to do with the design of the filler neck. It won't let the gas flow down into the tank fast enough and gas builds up to the nozzle and shuts of the pump. I usually pull the nozzle out about half way and don't have many problems. Sometimes I have to turn the nozzle at different angles to keep it running.
Old 01-06-2008, 10:46 PM
Yeah check it out and let us know. I know 100% that mine wont let me pump gas with the key in the on position. If I take the key out its fine
I've always wondered if mine was the only one that did that, although im sure its not.
Old 01-06-2008, 11:18 PM
bmxer8699's Avatar
mine did that, you have to lift up the pump and go in at an angle, the pumps around here have small necks for some reason.
Old 01-06-2008, 11:25 PM
That_guy's Avatar
yes bmxer i know what u mean. i have to apply force to get it to hold
Old 01-06-2008, 11:59 PM
chemicalstylez's Avatar
my 95 used to do that... thing was a royal pain to keep the gas flowing. i just moved the angles around like crazy to keep it going.
Old 01-12-2008, 11:29 AM
txh0tb0i972's Avatar
Yeah just angle it and it should be ok.....
Old 01-12-2008, 05:11 PM
Arc00TA's Avatar
Flip the bastard over so the trigger is on top? Good chance it has to do with the vapor recovery system they have to use now. If your cars vent line for that is clogged it will keep shutting off like that. Sometimes if you just wiggle the nozzle violently it will knock out whatever junk is in there and it will be good.
Old 01-12-2008, 05:14 PM
02silvaZ's Avatar
jacksonville, $3.23 and it will pump til your wallet is dry
Old 01-12-2008, 06:15 PM
Just filled up and it worked fine when i took the key out before i pumped.
I am going to try the exact same pump that did work last time to see what happens. Everybody wants the cheap costco gas so its hard to get that same pump(big line). I also was going to see what happen if i left the key in, but i just bought one of those lock gas caps so i had to take the key out. If nobody is waiting on me for gas next time i will experiment a little more. Thanks for all the replies and i'll let you guys know how i am doing with my future gas fill-ups.
