Has anyone broke a stock LS1 crankshaft ?
I might be reusing my stock LS1 crank in my 347 forged rebuild , running a D1-sc and up to 18 PSI .
Debating on weather i should use the stocker .
01 M6 SS camaro
Diamond -8.6cc blower pistons
Eagle ESP H-beams with ARP 2000 rod blots
DM performance LS1 bottom end engine girdle
ARP main + side stud kit , ARP Head stud kit
SLP ported oil pump + double roller chain.
TR 216-230 blower cam
Absolute speed ported heads (300 CFM at 550 lift) ferrea valves
LS6 intake/Ported T-body
Texas speed double valve spring kit
Compcams push rods , lifters
Harlen sharp Stock rocker rebuild upgrade
thats about everything!
01 M6 SS camaro
Stenod Perfomance has a couple guys pushing 1400+ on a stock crank, I believe Ohio Boys are also running a stocker in the 7's (1/4 mile). In fact, I don't know if I've ever heard of a stock crank failing before..
I ran one for two years (well over 300 passes) in my 347 and I'm running a stock (6.0L) crank in the new LS2 I just put in. Matter of fact the crank that was in my 347 was a well used crank out of Distortion_69's M6 car.
Crank and bearings looked fine when i took the 347 apart. I dont think I would use one in a 8000+rpm 1500hp setup but these are some pretty tough little cranks..
Depends, if you dont have a crank buying a new OE one vs an aftermarket one isnt a huge difference so I would buy aftermarket if I was starting from nothing. Pretty easy to find good used stock cranks cheap though. Like anything else it depends on your budget and power goals..
