prostar ?
I'd like to believe the 2 posts above- but I need to see it rather than read it at this point about either of those wheels. Especially since I am dying for the BS Lites.
Im pretty sure the convo pro's should just bolt on pretty easily i was going to order me a set 4 skinnes but i ended ordering the Jeg star wheels from Jegs $89.99 15x4's ill have them mounted today ill find out if i need any grinding hope you find what you want.....
Well dunno if this helps i got my skinnies (15x4 JEGS Sport Stars) today but i didnt get the tires on so to make sure they needed no grinding or spacer i slapped it on and it fit fine now all i need is a lil bit longer studs and i should be good to go.I'm not sure how much you have to grind 4 the rears but atleast 4 now no grinding was needed maybe you might wanna just get the fronts same route i went ill get the rears sometime later good luck!
