Generation IV External Engine - l76 intake on f body question
124TURBO
01-08-2008, 08:12 PM
I got my intake today and noticed there is no place for my throttle linkage bracket. is there a seperate kit or does it come with the mechanical t body?
spare tire
01-08-2008, 08:26 PM
This might sound stupid but you are not trying to bolt that onto the LS1 right? Because the L76 intake wont work on the LS1 heads.
124TURBO
01-08-2008, 10:19 PM
im using a 6.0L block and l76 heads
CamaroRick
01-08-2008, 10:39 PM
I used a holley 90mm cable driven tb, it comes with the cable mount bracket for the dbw setup intakes
formula17
01-13-2008, 04:45 PM
L76 intakes don't have a bracket on them, because they were on vehicles that had drive by wire set ups. You can get a bracket from SLP for a cable driven set up or like the other poster stated you can use a holley tb that already has the bracket on it.
Nick:secret2:
3stgstocker
01-13-2008, 05:20 PM
take ur stock bracket and weld a piece of 1.5 inch angle to it between where the to cables go in it and drill 2 holes in it for it to bolt to the 2 front intake bolts and u r done work perfect. someone actually sells them for like 70 bucks just like the 1 i made 4 my car. 70 bucks seems kinda high for a piece of 1.5 angle 2 inches or so long they r robbing people
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
