Painting Brake Calipers
Old 01-09-2008, 12:34 AM
xXSilencerXx's Avatar
Default Painting Brake Calipers
How hard is it? What do you use to clean the caliper and do you need to prep it in any other way? Do you just spray it or do you need to prime it, and does it stay on the car or do you need to take it off?
Old 01-09-2008, 08:22 AM
99zee's Avatar
Not hard at all. I left mine on the car. I ground the casting marks smooth then cleaned them up. A couple coats of primer, paint, decals then clear. I did mine over a couple of days while the car was sitting up.
Attached Thumbnails Painting Brake Calipers-rotorf3.jpg   Painting Brake Calipers-rotorr2.jpg
Old 01-09-2008, 10:01 AM
Cld069's Avatar
99Zee, very nice job, looks great!
I took mine off the rotor and put a garbage bag behind them so all that was exposed was the caliper itself (sorry, its kind of hard to imagine i know). I sprayed them down with brake cleaner and scrubbed at them a bit and then applied the paint and let them dry on a bucket. Not too difficult but I recommend leaving the calipers on and taking that approach due to ease and convenience. Take your time and they will turn out great.
Old 01-09-2008, 10:05 AM
fastSS_LS1's Avatar
Yours look really good 99zee.
Me and my friend did his calipers on his honda
All he did was sand them and put 2 coats of engine paint.
They looked pretty good for a 2 hour job.
Old 01-09-2008, 10:06 AM
99zee those look awsome. That's exactly what I wanted to do, the black and red. Did you just tape off the bracket from the caliper and vice versa? I saw the write up on ls1howto.com but he didn't paint the bracket.
Old 01-09-2008, 10:37 AM
xBROKEx's Avatar
its so hard to keep them clean though
Old 01-09-2008, 10:38 AM
kerryt1's Avatar
My brother and I painted his calipers / brackets the same way. A couple of tips:
1. Mask of the WHOLE side of the car with newspaper. We still managed a tiny bit of overspray, but it comes off with a claybar
2. Paint the hats and the edges of the rotors with silver for an added touch (wish we would have)
Old 01-09-2008, 10:53 AM
xBROKEx's Avatar
if you use the brush on stuff you wont get overspray
Old 01-09-2008, 10:59 AM
^^where do you get that? I've never seen it before.
Old 01-09-2008, 11:05 AM
TXws6's Avatar
the paint on kit is at just about any autoparts store... Dupli-color is probably the best kit. I need to do mine so bad, but i cant decide to go with the spray on kit or the brush.
Old 01-09-2008, 11:06 AM
The Guz's Avatar
I used the brush on kit made by dupli color. Works great and is very easy to use. The kit can be found at most auto parts stores.
For reference this is the brush on kit I used
http://www.duplicolor.com/products/caliper.html
Old 01-09-2008, 11:21 AM
Tough Mudder
Hilton's Avatar
I had all 4 of mine and the brackets powdercoated for $100.
Old 01-09-2008, 12:05 PM
zo6vette037's Avatar
+1 for the Dupli color kit. Here is mine
Old 01-09-2008, 12:31 PM
thmass6's Avatar
Unless you're doing the painting in a tornado, I don't think you need to mask the whole side of the car. Just do it in a garage where there's no wind. I bought the spray stuff and after a few coats, ended up brushing it on. I just sprayed a bunch of it in a plastic cup and used a brush to smooth out the paint. The spray alone left a kind of a runny look...so I'd recommend the brushed approach. I do mine once a year, and my car is only a weekend/nice weather driver, so yeah it is kind of a pain to keep it looking fresh.
Old 01-09-2008, 01:30 PM
ReFtheMC's Avatar
I've really been putting off doing this mod for a long time, i want to do it right away now
Old 01-09-2008, 02:03 PM
xBROKEx's Avatar
autozone sells the duplicolor kit FYi
Old 01-09-2008, 02:04 PM
xBROKEx's Avatar
thats cheap, the powder coating doesn't hurt the piston at all?
Old 01-09-2008, 02:14 PM
99zee's Avatar
Thanks for the kind words. Yes, I taped up the caliper and painted the bracket, then the other way around. Added the decals and cleared the caliper and bracket together.
Old 01-09-2008, 02:21 PM
Calstud86's Avatar
i love you guys..... so full of knowledge and ish...... I'm so glad I've got an LS1!
Now Val will have pretty red calipers too.
Thanks again, boys!
