Need to decide on a rear end, opinion's...
I was pretty dead set on a Strange 12 bolt, 33 splines, True-Trac, etc.
Now I'm thinking, hmm maybe I should go 9" (aluminum center) or even the newer Moser M9. I dunno about the S60.
So the car will always be a street car and probably always have an auto in it. At some point in time it might get a new block with I assume a good 500 streetable horses.
So what do you guys think?
I know JL-WS6 runs his 9 sec car with a 12 bolt. I just wanna do this once, but I would prefer not to have an anchor on the back or a spool or anything too insane. This will probably happen later this spring so I got time to think about it. The only thing I know for sure is I'll be going with a 3.73 gear (or the 9" equivalent). Oh and I hope to cut the occasional sub 1.5 60".
Thanks in advance.
Thanks in advance.
I won't competitively race, maybe a few dozen passes a year. I also only put about 7k street miles a year on it.
With that said I'm not overly concerned with harsh ride. I've already got a spohn TA, SFC, LCA's, poly motor mounts, etc. So it's not exactly squishy anyways
I just don't want this thing screaming at me when I'm cruising it either.
Race your car!
I've been fine with the mose 12 bolt so far, gears are a little loud but have been from the beginning. Still have the posi in it and all, but that will be switched for a spool in the near future.
I think for what you are planning, a 12 bolt will work, I think the S60 is total overkill, the moser M9 setup is nice, and if you are looking at doing a tq arm if ya haven't already that might be a good option.
LS1TECH Sponsor
For an automatic car, a Moser or Strange 12 bolt with the TrueTrac will be absolutely fine for you. If it were a 6spd, I'd say to go with the 9". In that case, Fireball is dead on:If you're wanting a good deal, we're Moser dealers and I have some very competitive prices on their stuff.
Thanks for the info all. If I go with a 12 bolt I think I will stick with the Strange. From what I have heard the Moser units are a bit hit or miss with gear whine and torque arm mount points.
I plan on installing the rear myself and the Strange seems like a piece of cake.
I really like those Moser M9 setups though. I already got the Torque Arm, but I could sell it off. However I am not sure if they offer a Posi option in that rear at all, I think only in the standard 9".
So far I think I'm sticking to my original plans then. The car will never be a single digit car, consistent high 10's is what I would like to see on motor.
I was debating between the Strange 12 bolt, and a Moser 9". I went with the 9" because I didn't want to screw around with sending in my backing plates. I got a Moser 9" with an aluminum center, spool, and 4.11's. It will be going in the car in the next couple weeks, I just painted it yesterday.
If you are interested I might be selling my mosler 12bolt. It has about 1k miles on it. Its a tru-track, 3 channel, 4.10's, fullu painted with POR15, upgraded axles and diff cover etc. I mostly autox and really want to get a Torsen T2R diff, they only make it for the 10bolt and 9in. let me know if you are interested
I have a strange just like you want and I would never buy one again I have busted mine more times then I can count already I am gonna be putting in a spool and the next time it breaks it is going to scrap metal. I would go with a 9 inch wich is cheaper in some cases also. check out epp they have good deals.
