General Maintenance & Repairs - Is my exhaust leak big enough to cause problems?
meangreenformula
01-09-2008, 01:25 PM
I recently installed Jet Hot Long tubes and bassani true duals and ever since i have had a ticking that gets louder when i accelerate. So i figured it was an exhaust leak. I went down under the car to check it out and saw that there was a small leak at the collector of the header. I just put my hand over it and felt a small gust of air. Is this significant enough to cause the ticking?
Thanks
jmm98LS1
01-09-2008, 01:31 PM
Yep, that's where your ticking is coming from. What kind of clamps do you have on the collectors? I've had good luck with lap joint band clamps.
meangreenformula
01-09-2008, 01:36 PM
Its not a clamp, its a 3 bolt flange. I got these (http://http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DG4752&N=700+115&autoview=sku) to bolt up to the header. It looks like the gasket is damaged, so that might cause the leak.......
2002_Z28_Six_Speed
01-09-2008, 01:49 PM
It will mess with your O2's. Farther down the line might be ok though.
bryan04h
01-09-2008, 02:10 PM
try replacing the gasket and hopefully that will help...but i would suggest getting it fixed soon
meangreenformula
01-09-2008, 02:19 PM
I'll check it out when i get home. I know i have some 2 extra gaskets, so i can swap it out in need be.
Thanks for the responses.
bryan04h
01-09-2008, 02:42 PM
2 extra? did you forget to install 2 of them maybe :lol:
meangreenformula
01-11-2008, 09:41 AM
lol, no i got 2 with the header reducers and 2 with the headers........
Anway, replaced the gasket, tightened the bolts down and the ticking is gone!
Thanks to all
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
