More Torquer 2 questions:)
Old 01-09-2008, 01:54 PM
Cole Train's Avatar
Default More Torquer 2 questions:)
ok i want to know from guys with experience with this cam. What length pushrods are best? If i go with this cam and do a 112+2 LSA on it will it still be lined up Dot to Dot? Also i'm putting in 243 UNMILLED heads and a .040 gasket to up compression a little but will my PTV clearance be ok? I'm using a LS2 chain setup so i won't be able to adjust there. Also the pushrods i wonder if are the right length as i already bought themi'm kinda new to the cams and Predator-Z is the one that suggested a 112+2 LSA. I'm just makin' sure it'll all bolt together ok and not have any PTV issues and still make the most power. Thanks a ton.~Cole~
All the mods going in:
LS6 intake
243 Z06 heads w/ PRC double springs
TR 7.4 pushrods stock length
ASP underdrive pulley
TSP longtubes w/ Offroad X-pipe thru B&B
Old 01-09-2008, 02:03 PM
sidewayz28's Avatar
im running 7.4 tsp hardened pushrods
Old 01-09-2008, 03:10 PM
BlackBullittSs's Avatar
7.4 push rod are fine, I ran a torquer 2 with 243 head Milled .o15 with a 2 degree on the cam on stock head gaskets with no problem
Old 01-09-2008, 03:30 PM
rickyracer25's Avatar
7.4 but you need to check and call TSP Jason or Jon will be happy to answer your questions
Old 01-09-2008, 04:51 PM
Cole Train's Avatar
thanks guys. i figured the stock length rods would work. Also i'm thinking i may have the heads stay unmilled and then just go with a thinner gasket. i'm guessing with a +2 advance and that gasket setup i'd be fine since i've read it should be. Thanks a bunch guys. maybe somebody else has something to add~Cole~
Old 01-09-2008, 11:23 PM
chrs1313's Avatar
curious what kind of PTVC are you guys having with a torquer 2 cam with stock heads and stock gaskets...
Old 01-10-2008, 02:15 AM
Cole Train's Avatar
i've been told by many top tech guys that there is PLENTY room with stock unmilled heads and stock gaskets that's why i'm wondering how much i can push it with a thinner gasket~Cole~
Old 01-10-2008, 09:17 AM
dab2pds's Avatar
plenty. i run the torquer 2 with 59 cc patriot ls6 stage II heads, morel lifters, stock head gaskets, and 7.35 hardened pushrods and spin to 6700 daily.
Dave
Old 01-10-2008, 09:45 AM
KONG's Avatar
LS6 intake
PVT clearance will be fine. Don't ever guess at pushrod length. Buy a pushrod length checker and do it yourself. I recommend using a .040 Cometic headgasket. Helps quench and boosts compression a little.
Old 01-10-2008, 10:53 AM
JS
JS's Avatar
We're going to run the Felpro .041 with a 65CC 243's and this cam.The base circle on Comp version of this grind needs a 7.425 but with the smaller head gasket the 7.40 works fine.
Old 01-10-2008, 02:35 PM
Cole Train's Avatar
Thanks JS and all the other guys. Really appreciate it~Cole~
