Who wants to see a LS6 versus VicJr comparison?
Old 01-09-2008, 02:16 PM
eb02z06's Avatar
Default Who wants to see a LS6 versus VicJr comparison?
I came to work and this was sitting on my desk!
So now it's the moment of thruth!
I'm going to dyno my car with my new blower-then swap over to the VicJr with a sheetmetal elbow and see if really makes a difference!
Then I'll be repeating the test again with a "bigger" cam to see what happens again with some extra duration. I would like to see if my CDNPERF 402 can buzz past 7000 rpm.
After getting Don's(Slowhawk's) input, Dave and I came up with a 238/246 which is in the car right now and then where going to try a 246/254. Goal is to make as much torque on the bottom end as the 347 was making but really shine up top as well as pull right to 7000 or beyond.
This will allow us to use a slightly bigger blower pulley to get more "belt wrap" which should lead to less slip.
My new blower should be arrive today as well-it's not what most people think it is! Hint-it's smaller than the last one!
Old 01-09-2008, 02:20 PM
Fireball's Avatar
need a cam optimized for each setup. Found what worked with LSx intakes vs what worked with vic jr intakes was different...much shorter runners involved
Old 01-09-2008, 03:02 PM
eb02z06's Avatar
Any suggestions bro?
Old 01-09-2008, 03:24 PM
smokinHawk's Avatar
give it to me
Old 01-09-2008, 03:25 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
subscribing
Old 01-09-2008, 04:35 PM
Photochop's Avatar
I bet you gain with the vic jr at higher boost (over 15 lbs) and lose with 10 and below. That intake will like the bigger cam though for sure.
Old 01-09-2008, 04:51 PM
SUPERBOOST's Avatar
Looking forward to the results!
Old 01-09-2008, 05:01 PM
SuperZ's Avatar
me too
Old 01-09-2008, 05:08 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
interested!
Old 01-09-2008, 05:24 PM
smoke20's Avatar
subscribing --
what im hearing is that below 10 psi the LS6 is better than the Vic Jr ???
ill be going to 12-15 psi later this year - maybe a vic and elbow in my future
Old 01-09-2008, 06:05 PM
eb02z06's Avatar
Crank pulley is 8", blower pulley I'll try first is 4", so doing the math with a 5.4 stepup means at 7000 rpm we should be over 74000 blower rpm-that should be over 20 psi!!!!
Whole point is to be able to run a bigger pulley and push the rpm to 7000 or beyond before falling off-we'll soon see!
I'm just waiting on Dave@CDNPERF to get this installed!!!!
It's a good thing Fern the Master Tech@CDNPERFcan swap cams and intakes in his sleep!!!!
Old 01-09-2008, 06:17 PM
stevieturbo's Avatar
I reckon the LS6 wins
I seen a boost increase when I swapped. Although it was very slight.
Old 01-09-2008, 07:03 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
To answer the thread title. Yes. Just do it. Try switching them. Then try switching cams with both intakes. If you can swing a cam designed for the vic jr. go for it, but don't waste money on another cam you'll never use.
We talked about that before though in the Patrick G thread about what the best intake manifold would be.
Old 01-09-2008, 07:21 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Can't wait to se the results Arun
Keith
Old 01-09-2008, 07:35 PM
SSilverSSurfer's Avatar
jeff(inspector12) is getting ready to do this also, from what me and him talked about. id like for him to do it on his 402/TT car and his 408/F1 car and see how each react.
cant wait to see results
Old 01-09-2008, 07:39 PM
7 Second Club
Phil99vette's Avatar
I'd love to see the outcome.
Old 01-09-2008, 08:21 PM
eb02z06's Avatar
I just have to pick up my new head unit and I'm ready to go. I'll do all new plumbing on the Vic Jr so swapping won't be too bad at all. I'll do a back to back test with the current cam then with the larger on as well. I'm also going to dump my catback to see if there is a significant gain in power there as well. Remember that his is going to be with a centri blower, pushing it to the limit-I would assume the results maybe different with a Turbo. I'll be posting results good or bad-hopefully this will help answer some questions!
Old 01-09-2008, 08:25 PM
LivingCanvas's Avatar
Finally some one is going to do it rather than talk about it
Old 01-09-2008, 08:35 PM
52172's Avatar
standing by for the results also!
Old 01-09-2008, 08:41 PM
eb02z06's Avatar
Everybody PM Sled28 and tell him to get that dyno in the ground!
I pm'd intakelbows for some options on elbows for C5's. I would also like to try that elbow from NitroDave-it clears stock hoods and if it works bonus. Anybody got one of those kicking around they don't need yet?
Edelbrock also came out with some cast elbows-one of them even has a divider to help split the airflow from the front runners to back runners.
I'm not sure how to post them but it's in there 08 new products brochure.
Quick Reply: Who wants to see a LS6 versus VicJr comparison?
