universal plug wires
i tried searching but only found something about soapy water which didnt help me
ive made a universal set of wires and cant get the boot for the coil end over the wires it gets stuck and i cant get it to budge who knows a trick
Try using some dielectric grease and twisting the boot between your fingers
as you push in the wire.
Sounds kinda kinky but it works for me!
You should be able to get this at the local parts store.
Even the so-so stores usually have it in one time use packs by the counter.
They may refer to it as "spark plug boot grease".
Good luck!
Good luck!
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Good luck!
Good luck!
