Best street only cam 3 choices
Old 01-09-2008, 08:55 PM
kingsey's Avatar
Default Best street only cam 3 choices
Gm hot cam 219/228 .525/.525 112LSA
Vengeance vrx 3 226/228 114 lsa
TR224 on a 114 lsa.
Full bolt on car. May add ls6 heads when I do cam. Stock stall never will see the track. Pure street
Thanks in advance. Looking for usable power on the street not to dyno 500 rwhp
Old 01-09-2008, 08:59 PM
52172's Avatar
vengeance cam just get a real good tune and it will have great daily driveability and make way more power than the two others. BTW I wouldn't even consider the GM hot cam its way outdated, about the only positive thing about it is its very easy on valve springs.
Old 01-09-2008, 09:02 PM
GT Griller's Avatar
I would take my patriot 226 over the tr224 anyday..sounds WAY meaner and from a couple of races with tr224 cars it pulls harder.
Old 01-09-2008, 09:23 PM
Midnight02's Avatar
Tough not to go with the Vengeance VRX3 out of the three choices listed above; I've heard nothing but very good things about that cam. That was my #1 choice, however I changed my plans a bit because I got a steal of a deal on a similar cam.
Old 01-09-2008, 09:29 PM
waterbug1999's Avatar
I would atleast put a 3K stall in... That will help kill some of your dead spots!
Old 01-09-2008, 09:34 PM
Disturbed Bird's Avatar
VRX3
Old 01-09-2008, 09:54 PM
jimmyjank's Avatar
I have a hotcam and springs ready to go in..it was free, gifted
from a relative.
I've seen lots of posts and opinions about this particular cam.
I just want reliability with some improved power.
This cam has very low mileage,but I did ride in the car it was in
and it had more sustained low end torque and seemed to hold nice
through the powerband..It seemed very jumpy..which is good.
My f-body already kicks my bigblocks ***...also f-body is my DD.
more opinions on the hotcam...? anyone's particular gain from hotcam
I've heard some say as much as 39rwhp .
Old 01-09-2008, 10:11 PM
52172's Avatar
the most it has ever made cam only if I remember correctly was around 395 rwhp, but that was with ewp and ALL the bolt ons ie" 90/90, UD pulley" Average more like 360-70.
Old 01-09-2008, 10:31 PM
jimmyjank's Avatar
Thanks for the input...My f-body is on the high mileage side of life
and as you stated ...it's easy on the valve springs.
Trying to guage some opinions on whether to keep the hotcam
for it's ease on motor..or upgrade a bit.
360-370 and some longevity sounds good.
Old 01-09-2008, 10:53 PM
TXZ28LS1's Avatar
the 224 cam is already a proven cam!! but out of those 3 i would go with the vengeance racing cam. vengeance racing has been making sick power lately!!
Old 01-09-2008, 11:30 PM
Zcleanest28's Avatar
+1 for a small stall, that and either the vengeance or the tr224 would make for a fantastic daily driver with some torque all over the range.
Old 01-09-2008, 11:39 PM
rocksws6's Avatar
I would look into Patriots cam and heads combo. LS6 heads and a 225/229 on a 114 LSA which is about the same range your looking at anyways. Its looks like a really good deal.
Old 01-10-2008, 12:18 AM
plaf713's Avatar
def the TR224, dont pick a cam (hot cam) that is almost the same as the stock cam, if you are going to do it, do it right, both a proven cams (vengance and tr224)
Old 01-10-2008, 12:45 AM
Evans752's Avatar
I would go with the Vengeance cam, I am not a fan of the TR224, I like the Hot Cam but they both perform about the same and the Hot Cam sounds better and Ive seen better times and mph out of the Hot Cam (1/4 mile) out of them 2. Vengeance stuff is prove.
Old 01-10-2008, 01:08 AM
COD02SS's Avatar
Who makes the Vengeance cam?
Old 01-10-2008, 09:38 AM
52172's Avatar
vengeance they are a sponsor here.>>>>>>
Old 01-10-2008, 04:16 PM
bad6as's Avatar
try a reverse split
Old 01-10-2008, 04:40 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
I'd throw out our Texas Speed 228R as well. With just .581"/.581" lift @.050, you don't need a huge expensive spring to get by either. These lobes from Comp have proven themselves time after time to make great steetable power!
Shoot me a PM or phone call and we can discuss your individual needs and get you taken care of!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 01-10-2008, 05:22 PM
WhosNXT's Avatar
I also say go with a small stall you will be glad you did. Also check out the comp 224/230 on a 114, its a great daily street cam.
Old 01-10-2008, 07:10 PM
realmendrivev8s's Avatar
Get a stall. A smaller one isn't bad at all for a daily and will work nicely with the cam
