Nitrous Oxide - n20 ????
J_Z28_T
01-09-2008, 11:51 PM
hey guys if i run 2 - 10 pound bottles and i only have one heater on one of the bottles and these bottles are of course joined on a T fitting will the heater work for both or do i need to get one more heater for the other bottle?
Z-RATED94
01-10-2008, 09:11 AM
Either get another heater, or ditch the one you have and use a nano system.
Nitro Dave's Nitrous Outlet
01-10-2008, 09:22 AM
You will have to put a heater on the other bottle as well. Otherwise you will never get the pressure up. Unless you just use on baottle at a time leaving the other bottle closed.
Dave
Mike@HSW
01-10-2008, 09:30 AM
If you want to save money by not getting another bottle heater simply close the valve on the other bottle. when the first bottle gets low close it and open the other.
I think that would be the most cost effective way to run a two bottle setup. If you decide to go with the dual heaters check out ours, Its easily one of the best on the market in terms of getting the PSI up quickly and retaining the heat.
http://www.harrisspeedworks.com/shop/product.php?productid=16665&cat=269&page=1
J_Z28_T
01-10-2008, 12:24 PM
thanks for all the help, i know what to do now!
daniel6718
01-11-2008, 01:55 AM
2 heaters are best
J_Z28_T
01-11-2008, 02:32 AM
2 heaters are best
u have 2 on urs right bro
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
