zo6 wheels?
zo6 wheels?
Will wheels from a 2006 zo6 corvette fit on a 93 z28? they are 18" x 9.5 fronts and rears are 19" x 12". I don't know the backspacing. If anybody has had experience with this or has any info on the backspacing on these wheels that would be very helpful.
The fronts have a +40mm offset and it will come real close to the fender edge. A 17x9.5 TT2 which futs fine has a +46 which means these will come out about 1/4 of an inch farther.
The problem will be the rears which shouls have a +59mm offset which should give it an 8.75 inch backspacing. That is 1 inch more than a 17x11 TT2. That could be a problem especially with the larger tire you would have to run.
Thanks
Tom
Thanks
Tom
