exhaust cut-out location?
Old 01-10-2008, 10:56 AM
mattgofaster's Avatar
Default exhaust cut-out location?
i'm gonna buy an exhaust cut-out soon basically cause it's a cheep way to improve sound a little with minimal if any gains. i'm really just going for sound right now.
my question is would it be better to have the cut-out weilded right after the y-pipe or right before the muffler? or would it really matter one way or another?
Old 01-10-2008, 11:08 AM
ryanfx's Avatar
wouldn't matter a whole lot. It would be louder inside the car closer to the y pipe.
Old 01-10-2008, 01:43 PM
luis_ws6's Avatar
I had mine on the I part in the back before it goes over the differential(near the back of the door). It might be better up in the front but youll hear more inside. I felt alot more power when I had mine. It varies on the car though.
Old 01-10-2008, 01:47 PM
EvoWake's Avatar
If you look underneath the car, at the I-Pipe (pipe connecting Y to catback) you'll see a nice area in the body where it will fit perfectly! hope this helps
Old 01-10-2008, 02:46 PM
Midnight02's Avatar
Mine was installed on the i-pipe just under the passenger side rear seat....it tucks in nicely there so I didn't encounter any clearance issues and you can run the wires through the grommet that is located close by (if you're installing an electric cutout).
Old 01-10-2008, 02:47 PM
SnakesRslow's Avatar
i agree
Old 01-10-2008, 07:28 PM
Trunion King
bene's Avatar
You want the cut out to be welded right at the I pipe bends to the axle just like it shows in the picture.
Old 01-11-2008, 04:37 AM
thanks for the help guys.
Old 02-09-2008, 08:51 PM
foreverzero's Avatar
Thats where I was going to put mine, but if you closed it, it would seem that there would be a lot of back pressure, since all of the exhaust would be trying to go out the blocked path (best route) Wouldn't that mess the car up? Not to mention kill a lot of hp with it blocked...
Old 02-10-2008, 12:45 PM
ShevrolayZ28's Avatar
That is where I put mine, but now that with the 9" rear, I think I'll have to relocate it.
Old 02-10-2008, 04:08 PM
can anyone answer my question?
Old 02-10-2008, 05:41 PM
Restricted User
socmguy's Avatar
Cutouts give decent gains. I'm cam only and gained 7rwhp and 6rwtq with the cutout open than going through the Magnaflows.
