Pontiac GTO 2004-2006 The Modern Goat
Averaging almost 27 mpg on my '04 A4!!
Old 01-10-2008, 01:00 PM
TORNATIC!!'s Avatar
Default Averaging almost 27 mpg on my '04 A4!!
I have a '04 A4 with Borla CB, K&N CAI, (Custom) Diablosport tune and TB Bypass. When I was stock I was lucky if I could get 20-21 mpg on the hwy. When I got the Predator and K&N CAI the gas mpg went up to 24-25 mpg hwy. Just recently I had Borla Catback installed. It seems the Predator has dialed it in nicely because today I was crusiing on the hwy and the gas mpg jumped up to 26.7 mpg!!
At lower speeds I'm getting 35+ mpg. Like if I keep her steady at 45 mph it stays constant at 36-37!!
So catback, cai, and the predator not only have made her quicker but it's helping me in the pockets.
What are some of you guys averaging on the hwy??
Old 01-10-2008, 01:17 PM
AshyLarry's Avatar
not calling you a liar but the 36-37 cant be right. 6 speed guys arnt even seeing those numbers. I can see high 20's at the right speed with those mods but thats about it.
I think I used to average mid to low 20's on the highway before the cam.
Old 01-10-2008, 01:28 PM
radkon's Avatar
I would put a wideband on it. If you are truly getting those MPG numbers, you are probably running dangerously lean.
Old 01-10-2008, 02:19 PM
TORNATIC!!'s Avatar
No I only get that 36-37 mpg when I'm at low speeds like in the 0-45 range.
Old 01-10-2008, 02:20 PM
TORNATIC!!'s Avatar
It's funny somebody said the same thing on ls1gto.com. Dangerous how?? What could happen if I am too lean??
Old 01-11-2008, 01:27 AM
KrautBurner's Avatar
you mean on the instant mpg display?
or running a full tank at that speed?
I used to avg 29-31 mpg with my M6 at 70-75mph,
but that was before the cam
Old 01-11-2008, 05:15 AM
TORNATIC!!'s Avatar
Instant Mpg Display. If I stayed at the speed I was at it probably would've stayed in that 25-26 range.
Old 01-11-2008, 07:29 AM
gmguy4life's Avatar
I thought you were using Instant, hell when I used instant i've gotten 35-38mpg on a flat stretch of hiway. The most I've gotten in my GTO was 28mpg using the Advarage display and that was on a flat stretch with mostly crusing at around 70mph.
Old 01-11-2008, 08:50 AM
radkon's Avatar
Yeah that was me (same username). If you are running lean anything above 16 AFR under load will most likely cause detonation. If the AFR gets too high 20+ detonation can destroy your engine.
Since you are using the instant MPG (which is useless BTW) you can ignore my comments.
Old 01-11-2008, 09:04 AM
Rob
Rob's Avatar
Best for me was 33. I had used 1/2 tank and cruised at 55mph because I was following a Tennessee State cop. I think the average speed for that was 53. Then he turned off and then cruised at 75-80mph the rest of the tank. Average a little over 30mpg with a average speed of about 62mph for the tank.
That was with the GT2-3 cam. Probably would have been higher with the stock cam. That was also the first real test of the lean cruise setting 3 years ago to see if it actually worked or not on GTO's.
Old 01-12-2008, 03:53 PM
TORNATIC!!'s Avatar
Yeah I need to reset my "mpg average" so I can see how all these mods have really improved the mpg. One thing I do know is true is my pockets have been a little heavier over the last few months. These mods definitely have helped her.
So running too lean is things not getting enough fuel and running rich is things getting too much??
Old 01-14-2008, 11:39 AM
radkon's Avatar
lean = not enough fuel
Symptoms are pinging, knock retard, unusually high mileage
rich = too much fuel
Symptoms are black sooty exhaust, poor mileage, possible lack of power.
Rich is safer, too lean and your engine can/will go pop
With your mods you are probably a bit lean, I'm willing to bet nothing too drastic but I'd get a tune as your next mod.
Old 01-14-2008, 04:45 PM
kenp's Avatar
You are kidding aren't you? Do you mean that when the instant mileage display on my '95 Deville says I'm getting 75 MPG, that isn't really true? I think I'm going down to the courthouse and file a cause of action against GM first thing tomorrow morning.
Old 01-14-2008, 07:37 PM
qwk93ta's Avatar
stop driving like a grandma....If you are worried about MPG buy a 4 banger. Go out and hammer your car a few times and remember why you bought a GTO.
Old 01-14-2008, 09:22 PM
PapaSmurf2005's Avatar
You're dumb, instant milage means nothing. Have a nice day.
Old 01-15-2008, 05:11 AM
TORNATIC!!'s Avatar
That hurt my feelings. Why are people so mean these days
Old 01-15-2008, 06:29 AM
ls 2 goat's Avatar
GOAT ABUSE!!! Get out there and drive it like you stole it or I'm reporting your ***.....
Old 01-15-2008, 05:04 PM
I said have a nice day to make up for being so mean.
Old 01-24-2008, 06:50 AM
ericwilloughby's Avatar
The MPG can be greatly skewed based on the LTFT's. It can be made to very 5 MPG easily with an injector slope adjustment.
What MPG do you really get? Miles\gallons to refill tank...
Quick Reply: Averaging almost 27 mpg on my '04 A4!!
