Small Block & Big Block Chevy Specific - how much HP this stroker will produce
proxemics
01-10-2008, 01:12 PM
383
11:1 comp
5.7" rod
dart pro 1 aluminum heads 200cc 64cc
air gap intake
holly 750dp
msd ignition system
hedman longtube
solid cam Duration 286/ 292, Lift .549/ .537
1.6 roker arms
can someone give me an estimation on how much hp will this combo make?
ZONES89RS
01-10-2008, 03:03 PM
Close to 500 easily, if not more perhaps, i need to know the .050 specs of the cam and LSA.
What kind of hood is on the camaro in your sig? Jongbloed?
Shawn @ VA Speed
01-10-2008, 03:51 PM
thats somewhere between 475-510 hp at the flywheel,real similar to our 505 hp engine,not sure of the flow #'s of the heads.
proxemics
01-10-2008, 05:03 PM
Duration at 050 inch Lift: 256 int./258 exh.
LSA 108
the hood is made by a local fiberglass shop
proxemics
01-10-2008, 05:14 PM
good I don't want to exceed 500HP NA
Can I spray 150hp over this ? my rods are I beam GM performance and the crank is SCAT steel
Shawn @ VA Speed
01-10-2008, 05:28 PM
is it a forged or cast steel crank?
67SS&99SS
01-10-2008, 07:09 PM
If they are the gm "pink" rods, i would not spray nitrous on top of that. They max out in the 450-500 hp range. If you are going to spray it, get some h-beam rods, such as eagle esp's. As previously stated, do you have a forged steel crank and pistons?
67SS&99SS
01-10-2008, 07:12 PM
LSA 108
With a cam that big, I would consider putting a victor jr, or super victor type intake on that motor. It has to peak well over 7000 in a 383. Its good to see that it is a solid cam. Is it a solid roller or a flat tappet?
ZONES89RS
01-10-2008, 08:46 PM
Yep, 500 is easily possible, but as stated, you are really pushing those rods.
1997bird
01-11-2008, 01:00 AM
I'm going to guess 515 HP & 539 TQ, at least that is what my Dynomation program thinks. Those are some nice heads and will make plenty of power. Make sure to gasket match the intake your heads, Edlebrock made some tiny openings for their casting's. I wouldn't worry about the crankshaft, the rods will break way before the crank will. If you haven't ordered your cam yet, you will want to favor the exhaust side a bit more. Here are some figures for a cam that I have found to work quite well with those heads as cast:
Adv. Duration 288/296
@.050 Dur. 250/258
Lift w/1.6 rocker .600"/.600" (hot lash @.020"/.022") net lift .580"/.578"
LSA 111*
ICL 107*
This cam also makes good intake vaccum for your brakes as well.
proxemics
01-11-2008, 05:02 AM
are these rods good for 150hp nos over this stroker?
http://store.summitracing.com/partdetail.asp?part=SCA%2D6570021&autoview=sku
I guess the crank and pistons are forged
proxemics
01-11-2008, 05:04 AM
solid flat
Shawn @ VA Speed
01-11-2008, 06:17 AM
those rods would be fine,but you need to know what the crank and pistons are before you start spraying them
proxemics
01-12-2008, 09:11 AM
sure :)
thanks
