car wants to stall when warm
Old 01-10-2008, 05:58 PM
rob scott's Avatar
Default car wants to stall when warm
ok when my z warms up it wants to stall out at a stop. the oil drops to 20 and it goes down to 600 rpms. i checked the oil and its right on the mark. when i go to stop the car will slow down then it feels like im giving it gas because it wants to keep movin once its stopped. the ses light is on and its from the 02 sensors. but tomorrow after work im taking it to get it scanned again to make sure its still the 02 causing the ses light. the car has a 3600 yank stall and lt headders, untuned because im putting a cam in this spring. could not being tuned cause this?
Old 01-10-2008, 06:00 PM
RAGENZ28's Avatar
I'd try unplugging the battery and pulling the fuses and let the computer restart and see if it goes away, mine would low idle for now reason once in a big while, or idle really high like 3k for no reason, it's a pos computer thing.
Old 01-10-2008, 06:01 PM
rob scott's Avatar
how many fuses are in your z because i have like 15 in mine and it doesnt seem right.
Old 01-11-2008, 08:44 AM
radkon's Avatar
When your car is warm it is going into closed loop mode using the O2 sensor to adjust fueling. If the O2 is bad then its either adding or removing too much fuel, your O2 sensor is bad, replace it.
