ls1 camaro 6speed top speed in gears 1-6
hey guys, im jw how fast a stock ls1 camaro 6spd with the stock 3.42s will go in each gear i was thinking like 45,80,110,?,?,? but im not sure
It will if you've got the horsepower and raised rev limiter. But yeah, a more realistic number for stock is 170. I have been close to 160 and am confident that my car could do 180. Pegging the 155 speedo is plenty fast enough for me though.
ive been curious about this also, if you go to 4.10's in an m6 will your top speed still be in 5th gear which would redline at 151 or would you be able to partially pull 6th gear to say 160-170?? not that i will ever find out i jus want to know
stock car with limiter removed the most I've ever seen was about 165mphand that's was with several diffrent car's. 6th gear doesn't pull any higher then were 5th gear got you too. to much wind restance. also the limiter is 156 or 159 I don't rember which right off the top of my head.
I pulled my 02 Z28 M6 to 161 by the Nuvi Nav. System and the car is stock with a SLP LM2 Exhaust and if you pull that in 5th gear and then shift to 6th
it will fall back to about 138
