EXCESSIVE81
01-11-2008, 08:50 AM
i am trying to complete a ls2 and can not find a few part numbers:
front cover bolts
rear cover bolts
oil pan bolts
ls3 rocker arm bolts/stubs and nuts
ls3 rocker pedastel bolts
valve cover bolts
"dumdbell" oil plug
cam retainer plate
cam retainer plate bolts
water pump bolts
cam gear bolts
coil brackets to valve cover bolts
crank pulley bolt
THANKS
shane
front cover bolts
rear cover bolts
oil pan bolts
valve cover bolts
"dumdbell" oil plug
cam retainer plate
water pump bolts
cam gear bolts
crank pulley bolt
THANKS
shane
