soslo
01-29-2003, 08:08 PM
I added another calculator to my site that creates a chart of gear ratios that match your inputs.
So for example, you enter your tire diameter and transmission ratio that you finish the 1.4 in, and the calculator makes a table of gear ratios for you to choose from based on your desired RPMs and max trap MPH.
It is harder to explain than it is to use, check it out and let me know what you think. Or just let me know if you'd like to see another calculator on the page, and I'll add it if I am able
http://www.freewebs.com/soslo/formulas.htm#findgear
