What are you guys using for throttle linkage brackets?
Old 01-11-2008, 06:22 PM
hashtagBMW
Speed Density's Avatar
Default What are you guys using for throttle linkage brackets?
Any setup as long as its EFI will give me some ideas.
I have a wilson 90* elbow and accufab TB, I dont know where to start on mounting some bracketry for the throttle and TV kickdown.
Ideas? Pictures?
Tony.
Old 01-11-2008, 08:35 PM
LS1MCSS's Avatar
I spent a few hours making mine.
Old 01-12-2008, 02:58 AM
hashtagBMW
That looks good, and you need a kickdown for the 200r you have!
Tony.
Old 01-12-2008, 09:02 AM
TT402LS1's Avatar
Im looking for ideas as well! LS1MNSS where did you get the black bracket you mounted on your TB?
Thank - Ron
Old 01-12-2008, 10:30 AM
LS1MCSS's Avatar
It's just a small piece of metal I had in the shop. It took a while to get the geometry correct for the throttle valve cable connection. I probably spent 5 hours on the two pieces, but I wanted it to look decent.
Quick Reply: What are you guys using for throttle linkage brackets?
